GSX-R1000 2007
  • Keskustelun aloittaja Keskustelun aloittaja vma
Uutta tossa gixussa on kakspuolanen takavanne.
Joo, ei jaksa tehä kunnolla.
Tässä olis jo "munaa"
From a press release issued by Suzuki...
2007 SUZUKI GSX-R1000
To the team of Suzuki engineers responsible for the GSX-R1000, Own The Racetrack is not just a slogan, it is a way of life.
It’s a life dedicated to making the most successful open-class motorcycle in the history of production-based racing even better. The key is the motorcycle’s ability to do precisely what the rider wants, when the rider wants, how the rider wants. Accelerate, brake, corner, repeat. Make it easier for the rider, and the results will show.
Once again Suzuki has raised the level of open class sportbike performance. The 2007 Suzuki GSX-R1000, it’s the reason why Suzuki riders Own The Racetrack.
The basic architecture of the compact 999cc liquid-cooled GSX-R1000 engine is well known, a model of race-winning design: Bore and stroke of 73.4mm x 59.0mm, forged aluminum-alloy pistons with short skirts and cut away sides, chrome-moly steel shotpeened connecting rods, hollow dual overhead cams, and lightweight titanium valves. Add to that a close-ratio six-speed transmission with staggered transmission shafts, an adjustable back-torque limiting clutch and a gear driven secondary balancer shaft for reduced vibration.
A new more compact Suzuki Dual Throttle Valve fuel injection system is in place for 2007 with 12 smaller holes instead of four for improved fuel atomization and because the injectors are more compact and emit a finer spray, the secondary injectors can be positioned at a steeper 30 degree angle aimed directly at the intake ports for improved throttle response. Intake and exhaust ports are re-shaped and eight percent larger and exhaust valves are 2mm larger (26mm vs 24mm) to work with more aggressive camshafts and Iridium spark plugs are used for optimum combustion and longer life. Also a new Idle Speed Control (ISC) system improves cold starting and stabilizes engine idle under various conditions and larger ventilation holes between cylinders reduces pumping losses.
The Suzuki Advanced Exhaust System (SAES) features equal length head pipes feeding a collector, a short mid-pipe and a unique under engine chamber that leads to two short aluminum and titanium mufflers on each side. This system nearly doubles exhaust internal volume while lowering the center of gravity, centralizes the mass and improving aerodynamics. A proven Suzuki Exhaust Tuning (SET) valve finds a home on the mid pipe and the combination of the Suzuki PAIR system, a catalyzer and a oxygen sensor equipped closed loop engine management system work in conjunction to reduce emissions and improve engine efficiency.
A new larger radiator features a trapezoidal shape typically seen on works race bikes with nearly a ten percent increase in cooling capacity. The oil cooler is re-shaped with a third more cooling capacity and the oil pump is larger for increased flow.
Controlling the new 2007 GSX-R1000 is a new engine management system with massive computing power with four times the capacity of the previous models. The new ECM controls not only the fuel injection and exhaust systems but also make it possible for the rider to select from three performance settings to match riding conditions, using a three way switch mounted on the right handlebar. Engine mapping will vary for each setting and each map was developed using experience gained building racebike maps for rainy, mixed and dry conditions. Switching from map to map will be instantaneous making it possible for the rider to use different maps for different sections of the racetrack. A new self adjusting hydraulic clutch system uses a radial master cylinder and minimizes the change in clutch feel over the course of long races.
Taking lessons learned from the racetrack, the 2007 GSX-R1000 utilizes an all-new frame built to improve mass centralization by moving the rider toward the center of the wheelbase with a shorter fuel tank and moving the seat forward. The new frame is engineered to deliver the optimum rigidity balance for precise handling even at full lean. Constructed from five main aluminum alloy-castings the new frame uses less parts and less welding for improved accuracy and reduced weight. A new lighter and more rigid aluminum alloy swingarm finds a home under a two piece subframe and features a new rear shock mounting system with a link that pivots on the swingarm itself for improved traction and reduced side loads.
Taking lessons learned from the latest GSX-R600 and GSX-R750, the new GSX-R1000 also features three position adjustable footpegs for maximum rider control and maneuverability.
New high and low-speed compression damping adjustability is built into both front forks and the rear shock along with adjustable rebound and preload adjustments for maximum rider control. The outer tubes of the front forks are now larger in diameter below the lower triple clamp to improve rigidity while the DLC coated fork tubes remain at 43mm. Fork offset has been changed from 30mm to 28mm, increasing trail from 96mm to 98mm. Front wheel travel has also been increased from 120mm to 125mm.
The ’07 GSX-R1000 also benefits from new front brake rotors and brake carriers. Each 310mm disc is attached to the carrier using 12 floating mounts instead of 8 for improved heat transfer away from the disc.
The disc is also slightly thinner, measuring 5.0mm vs 5.5mm for reduced weight. The rear brake is a 220mm rear disc working with a single piston caliper now mounted above the swingarm, to reduce the effect of rear suspension movement caused by braking.
Handling will also benefit from the use of an all-new electronically controlled steering damper. A solenoid valve operated by the engine management system controls a tapered needle, increasing or reducing oil flow for increased or reduced damping force.
Extensive wind tunnel testing led to new and improved bodywork for the 2007 GSX-R1000, with an aggressive style and an overall reduced frontal area for amazing aerodynamic performance. A slightly taller windscreen also makes it easier for the rider to tuck in on the racetrack. New vertically stacked headlights also debut on the new GSX-R1000. The multi-reflector headlight has a new simpler shape and uses a 55w H7 halogen bulb positioned over a 70mm projector high beam.
Because everything else is new on the ’07 GSX-R1000, the instrument cluster is new as well. The new instruments include a step motor controlled analog tachometer, digital LCD speedometer, dual LCD tripmeters, an LCD clock, coolant temp/fuel injection readout, gear position indicator and a programmable LED engine rpm indicator light. A new LCD engine mode indicator displays which performance setting has been selected by the rider.
Hienoja pelejä on ihan tuolta k5 lähtien ja sellaseen vaihtuu omakin. Putkia en ees viitsi ihmetellä kun yks puolinen yoshi tulee kuitenkin. Sama kun alkais noita rekisterikilpihässäköitä ihmettelemään. Ei mitään väliä noilla putkilla ja kilpitelineillä kun ne lähtevät ekana päivänä jossei ihan roskiin mut ainakin hyllylle ihmettelemään
Suzukilla taitaa olla diili viripönttöjen valmistajien kanssa, kun laittavat sellaisen näköisiä putkia että pyörän oston yhteydessä on se 500-1000 lykättävä lisää, jotta pyörästä saa fiksun näköisen.
Voisivat myydä kokonaan ilman niin säästyisi irti ruuvamisen vaiva ja voisi valkata millaisen itse haluaa. Eikö autoissakin ole henk. koht. valintavaihtoehtoja.
Tuo totta.Kun 2006 zx10r:ssäkin kaks putkea niin hintakin slipareita kohtaan on x2!Esim akratx2 n.1200e!Halpaa kun mikä!?!?
Miks ihmeessä sinne pitää sotkea 2 pönttöä vaikka varmasti pärjää yhelläkin ja hinnasta puolet pois?? Todella helppo operaatio hitsata sinne muutospala 2-->1 ja pistää yks pönttö tilalle
2007 mallissa lennossa vaihdettava kolmiasentoinen power mapping switch:
täysiteho 187
vakio 150
wet 120 hv
ja kaikkea muuta uudistusta:
ohjausiskari (KYB) solenoidi säätyy nopeuden mukaan
runko uusittu
säädettävä swing pivot point (ostettava race kit erikseen)
neljäkertaa tehokkaampi engine management system
mittaristo
lähteenä tämän viikon MCN
täysiteho 187
vakio 150
wet 120 hv
runko uusittu
mittaristo
Kuka haluaa ajaa 120 heppaisella Gixerillä? Väittänen, että täysi teho on useimmilla ajajilla päällä koko ajan
Toisekseen, mitenköhän tuo mapping vaikuttaa. Tiputtaako se vaan huipputehoja vai koko kierrosalueen tehoja? Koska välitykset eivät kuitenkaan muutu tehojen vaihtuessa. Luulisi tiputtavan koko kierrosalueen tehoja. Eihän siitä muuten mitään iloa ole.
täysiteho 187
vakio 150
wet 120 hv
runko uusittu
mittaristo
Sadekelillä tuo säätömahdollisuus voi olla ihan järkevä. Lisäksi luulisin että tuolla on vaikutusta polttoaineen kulutukseen, eiköhän siinä ole seoskin hieman laihemmalla noilla pienemmillä asetuksilla. Eli jos kruisailee matka-ajoa niin voi naksauttaa pienimmän asetuksen ja kenties ajella vähä pienemmällä polttoaineen kulutuksella.
Toivon mukaan noita mäppejä saa sitten jollain ilveellä muokattua asianmukaisilla laitteilla tietenkin. Radalle toi vois olla aika bueno, voisi ladata valmiiksi pari eri karttaa esim. vakioputkille ja viriputkille tai suoralle virille ja suoralle virille db-killerin kanssa.
Kunhan nyt saadaan vähän lisätietoa asiasta ja kokemuksia niin luulempa että tuo säätömahdollisuus alkaa vaikuttamaan ihan mukavalta ominaisuudelta.
täysiteho 187
vakio 150
wet 120 hv
runko uusittu
mittaristo
Nuo teholukemat lupaa kyllä erittäin hyvää. Vakioputken tilalle täysputki, filtteri ja säädöt niin ollaan luultavimmin melko mukavissa lukemissa.
Jos pelkistä tehoista puhutaan niin alkaa vaikuttamaan siltä, että gixxeri on kurko perusvireillä myös seuraavat pari vuotta, rykkösen pitää kehittyä moottoriltaan huomattavan paljon jotta pääsisi samoihin lukemiin (onhan pyörässä toki muutakin kuin tehot).
Ram air tehosta tuossa puhutaan mutta sen varmaan tiesittekin.
Eli samat tehot kuin K5 ja K6. R1;sessähän on ram air teho 183hv nyt joten samoilla tehoilla tuo jatkaa,paino vain noussut. Mutta odotetaan kun ensimmäiset lyödään penkkeihin,niistähän sen sitten näkee mitä todellisuudessa on.
Mistä luit että ram-air tehot? Ihan satavarmasti moottorin tehot ovat nousseet K5/K6 tasosta, moottori muuten sama mutta uudet injektorit, imu- ja pakokanavat muotoiltu uudelleen, suuremmat pakovenat ja jyrkemmät nokat.
Voihan se tietty olla, että uusi putkisto rajoittaa tehot samoihin lukemiin kuin mitä nykyisessä on mutta viripotentiaalia on ainakin lisää, siitä uskallan olla varma.
Eikai se pelkkä Max tehokaan ihan kaikkee oo..
Suitsallahan on ollu teho/vääntökäyrät muita parempii jo pitempää..
Luulisin, että nuo rajummat nokat yhdessä isompien kanavien kanssa syö vähän alavääntöä..
Tuplaputket menivät pois muodista 20v sitten. Muodilla on tapana toistaa itseään, joten tuo tuplajuttu on tulossa takaisin.
Porukka on vain katsellut yksipönttöisiä niin kauan, että kaksi näyttää pitkästä aikaa oudolta. Siihen tottuu, uskokaa pois.
On siihen varmaan ihan oikeita syitäkin. Tehokilpa käy kuumana ja yhdellä vaimentimella alkaa olla vaikea saada riittävää virtausta ja samalla vastata tiukentuviin melu- ja saastemääräyksiin. Pyörään ei oikein voi pönttöjä laitaa peräkkäinkään tai kasvattaa pituutta tolkuttomasti, varsinkin kun lyhyet vaimentimet ovat in tällä hetkellä.
