2.4.3.1 Balancing various motorcycle concepts
a) In order to equalise the performance of different brands of machine
rev limits will be individually applied to each brand.
b) Each season will begin with the same rev limits as the previous season
finished.
c) The rev limit will be adjusted according to 2.4.3.2.
d) Updated machines with the same basic engine design will continue
with the manufacturers previous rev limit. Any new machines entering
with a redesigned engine will have their rev limit set by calculation.
e) The initial rev limit will be the dynamometer measured rev limit of
3rd & 4th gear averaged, plus 3% or 1100 rpm above the dyno measured
max horsepower rpm of a production machine, whichever is lower.
f) The limiter in all gears will be analysed to check for anomalies.
g) The dyno test will take place during the homologation inspection.
(See Part 4.0 Homologation, 1.4.b)
h) The Superbike Commission can at any time modify the handicap system
to ensure fair competition.
2.4.3.3 Rev limit
The manufacturer specific rev limit will be adjusted in increments of 250 rpm (up or down).
The rev limit will be controlled by the manufacturers software and will be monitored by the FIM/DWO approved rev-logger (see 2.4.9.1). Over rev because of downshift will be ignored. ECU Hard limiter must be set to the WSBK specified rev limit.
WSBK Initial rev-limit
Brand Proposed
Aprilia 14700
BMW 14900
Ducati V2 12400
Ducati V4 16350
Honda 14550
Kawasaki 2018 14100
Kawasaki 2019 14600
MV Agusta 14950
Suzuki 14900
Yamaha 14700
2.4.4 Minimum weight
All machines 168 kg
2.3.16 Concession parts
The motorcycle manufacturer may nominate themselves, their subsidiary or one company as the supplier of the engine concession parts. The nominated party will be known as the concession part supplier.
All concession parts must be approved by SBK Technical Director before they are allowed to be used.
For the updates of concession parts please see 2.4.3.4.
Concession parts remain legal for use until the end of the season following the season in which they were last updated/replaced.
Concession Parts
Part Price Limit Lead time Notes
Valve springs single € 60.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
Valve springs double € 75.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
Collet and Retainer € 45.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
Camshaft € 1,000.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
Camshaft Sprocket € 100.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
Shim bucket € 45.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
2019 Cam chain € 300.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
2019 Flywheel € 1,000.00 10 weeks 3 sets by January 10th if ordered then 10 weeks.
The parts must be documented with drawings, dimensions, pricing
2.3.18 Approved parts
The approved parts must be supplied to the following championships upon request:
i. World Superbike Championship
All approved parts must be approved by SBK Technical Director before they are allowed to be used.
Approved Parts
Swingarm € 10,000.00 10 wks At least 1 must be available per rider in WSBK within 2 races of its first use.
Triple Clamps € 2,000.00 10 wks At least 1 must be available per rider in WSBK within 2 races of its first use.
Linkage € 1,500.00 4 wks At least 1 must be available per rider in WSBK within 2 races of its first use.
SBK Front Forks € 10,000.00 6 wks
SBK RCU (Shock) € 6,500.00 6 wks
WSS/SSTK Fork Kit € 2,200.00 6 wks
WSS/SSTK RCU € 2,000.00 6 wks
WSS300 Fork Kit 6 wks
WSS300 RCU 6 wks
SBK Brake Various Various
Sump 2019 € 2,000.00 10 wks 3 sets by January 10th if ordered then 10 weeks.
Superbike Kit System € 8,000.00 8 wks Only reference team may develop these parts
