I have never seen so many differing opinions about how this little, inexpensive device operates and affects your bike!! So, I have decided to address some of the functions and try to clarify it's use.
The TRE is a device which allows much better throttle response in the first 4 gears on all EFI Suzuki sportbike models.
What the manufacturer has done is to make a SEPARATE IGNITION MAP FOR EACH GEAR.
This has been done for either safety and/or emissions reasons. However, it limits the power and smoothness of your bike in the first 1/2 turn of the throttle in gears 1 through 4.
They were clever in the design of this timing retarder. It still allows full timing at full throttle. As you shift up through the gears, the amount of throttle needed to access the advance curve decreases, until you make it into 5th gear and then it's gone. You have nice, smooth operation. Wouldn't you like your bike to respond just as smoothly in the lower gears?
That is why I invented the TRE !
I am the the original inventor of this product !!
I couldn't stand how these particular models ran in traffic. In addition, while going into a curve and closing the throttle in 2nd or 3rd gear the engine would come back with a big jerk when reapplying the throttle. After my TRE installation, gear changing was much smoother.
The TRE will disable the speed limiter on the 2001 - 2004 GSXR1000 and 2001 - 2004 GSX1300R. This due to the fact that the ECM does not see the 6th gear ignition map, which has an earlier rev-limiter.
Quick facts about the TRE
The TRE is a direct "plug in" installation to your bike - no cutting or splicing
The TRE has no effect at full throttle
The TRE does have an effect at throttle openings up to 1/2 in gears 1 through 4 at ANY rpm
The TRE will disable the speed limiter on the 2001 thru 2004 GSXR1000 and 2001 thru 2004 GSX1300R
The TRE will disable the speed limiter and high rpm horsepower/timing retarder on Suzuki V-Strom models only
The TRE does NOT affect full throttle horsepower
This has been verified on the dyno as well as on the road under controlled conditions
Our TRE has also been tested by Sport Rider Magazine, with rave reviews
The TRE is for "race use only"
The TRE does not comply with your warranty
The TRE does not comply with federal emission and/or safety laws.
