Prätkien talvirenkaiden käytöstä
  • Keskustelun aloittaja Keskustelun aloittaja Koris
Mistäs tässä alunperin keskusteltiin?
Kitkat vastaan nastat..?
Z -kirjaimesta.
Eli onko se nopeusmerkintä vai rakennemerkintä?
Noiden Petrin postaamien linkkien mukaan se on nopeusmerkintä, paitsi että jos nopeusluokka on yli 240 km/h, niin sitten tarkempi nopeusmerkintä on siinä "service description" osassa, esim. (73W).
While a Z-speed rating still often appears in the tire size designation of these tires, such as 225/50ZR16 91W, the Z in the size signifies a maximum speed capability in excess of 149 mph, 240 km/h; the W in the service description indicates the tire's 270 km/h maximum speed.
225/50ZR16 in excess of 240 km/h
205/45ZR17 88W 270 km/h
285/35ZR19 99Y 300 km/h
“ZR” Rated Tires
When “ZR” appears in the size designation with the service description, the maximum speed is as
indicated by the service description.
Täällä on The European Tyre and Rim Technical Organisation (ERTRO)
joka on stadardoinut renkaat ja merkinnät Euroopassa.
Ohessa lainaus:
"N.B. Speed category markings as appropriate, shall be included in the tyre size designation in place of the construction code, as follow:
Tyres suitable for speeds above 240 km/h shall be marked with the appropriate Speed Category Marking ‘V’, ‘VB’, ‘VR’, ‘ZB’ or ‘ZR’ e.g. 120/60 VR 17.
Speed Category ‘V’, ‘VB’ or ‘VR’ Tyres suitable for Speeds over 240 km/h shall be marked within brackets with a Service Description where the Speed Symbol is ‘V’ e.g. 120/60 VR 17 (55V).
Speed Category ‘ZB’ or ‘ZR’ Tyres suitable for Speeds up to 270 km/h shall be marked with a Service Description where the Speed Symbol is ‘W’ e.g. 120/60 ZR 17 55W.
If they are suitable for speeds over 270 km/h, the Service Description shall be marked within brackets, e.g. 120/60 ZR 17 (55W).
The maximum speed approved by the Tyre Manufacturer may be marked on the Tyre as for example V250 to identify a maximum speed of 250 km/h."
ERTRO Instructions on tyre use
mihinkäs ne mopon talvirenkaat unohtu? eikös ne ollu pointtina?
pointti taisi olla talvirenkaat z/w nopeusluokassa
Joo,vähänkö hienoa olisi päästellä jäällä +270km/h kyykyllä
Tuo Z-merkintä on jäänne ajalta, jolloin ei vielä ollut erillistä nopeusmerkintää kantavuusindeksin yhteydessä esim. 120/70 ZR 17, jossa siis nopeusluokitus on yli 240 km/h. Nykyään kuitenkin käytetään yleisesti tuota erillistä nopeusindeksiä kantavuusindeksin yhteydessä, joten 120/70 ZR 17 (58W) -merkinnän sallittu nopeus on yli 270 km/h. On huomioitava, että merkinnässä 120/70 ZR 17 58W (W ilman sulkuja) suurin nopeus on 270:een asti. Sain joskus tilaisuuden jutella Metzelerin tehtaan edustajan kanssa ja ihmettelin hänelle samaa erikoisuutta (kaksi nopeusmerkintää). Hän kertoi sen johtuvan siitä, että nopeuskestävyyden kasvettua on tullut tarve lisätä siitä erillinen merkintä. Määräävää on kuitenkin se, mitä on merkitty kantavuusindeksin yhteyteen.
Onhan näitä "kummallisia" merkintöjä, esim. 170/60 VB 18 (73V) V260 TL, jossa ensimmäinen V tarkoittaa 240:een asti, toinen V (suluissa) yli 240 ja lopussa määräävä tarkennus 260:een asti.
Näytää olevan vaikeata myöntää olevansa väärässä.
Ei ollenkaan.
Pystyn helposti myöntämään olleeni väärässä. Ja olinkin väärässä: vaikka nykyajan prätkärenkaissa se Z ei kerrokaan enää todellista nopeusluokkaa (vaan se nopeusluokka on siellä kantavuusindeksin yhteydessä), niin se Z ei ole kuitenkaan rakennemerkintä (esimerkiksi siitä, missä kulmassa vyöt kulkevat), vaan nopeusluokkamerkintä historiallisista syistä. Näin luulen mä nyt tällä hetkellä.
Motiivini näissä väännöissä ei ole olla oikeassa tai väärässä, vaan oppia lisää tietoa.
Ystävällisin terveisin Antti
Lupasin laittaa vastauksia kyselyihini.
Tässä on yhden rengastehtaan "Head Tech Guy":n meiliä, jätän kuitenkin lähettäjän tiedot pois ja toivon, ettette lainaa tätä viestiä muualle. Vastaus on kuitenkin mielestäni tyhjentävä.
ZR means:
Z is for speeds above 240 kmh (149 mph).
This is largely redundant now as the tyre will probably also be 'W' rated which means for speeds up to 270 kmh (169 mph).
If the W is in brackets, this means for speeds above 270kmh (169 mph) but at reduced loads.
It is still left in radial sizes for historical reasons.
The R means radial. It has nothing to do with the type of radial construction which can be for example aramid or steel, and doesnt have to be at 0 degrees either, many are however.
Mutta eiköhän tästäkin tule asia selväksi, eli BajaHill on oikeassa tuon Z-kirjaimen suhteen.
