G
Guest
Guest
In last month's issue of MCN, I recall a mention of a "secret" procedure to raise or lower the C.O. output of the new FZ1 engine...effectively adjusting richness/leanness. (to be used only by authorized Yamaha techs)
The implication was that a certain sequence of button pushings (the 2 buttons below the Display) would allow the bike's fuel-programming to be accessed.
I'm unaware of what that sequence is. I did look at the full service manual; all it has is a description of error codes, and the way to cause them to be displayed.
Can anyone confirm that Yamaha DOES have a "secret" way to actually access the fuel richness "map" on the new FZ1, and if so
what it is?
Tämmönen otti silmään netissä surffatessa.
Oletteko kuulleet moisesta, vai onko tuo taas jotain pienen pojan haaveita?
what it is?
