Tavaraa Louikselta, tilaus tehty, MITMIT??ÖÖ
  • Keskustelun aloittaja Keskustelun aloittaja Pegasus
Eli nyt siis tilaus jätettu, siispä kysymys kuuluu: Laitoin maksuehdoksi sen toisen, en siis visaa, "Zahlungsmodus: Vorkasse". Tarkoittaako tämä siis jälkivaatimusta??? Ts. odottelen pakettilappua postista ja sitten menen lapun kanssa pakettia hakemaan ja samalla suoritan maksun postiin?? Näin ainakin itse ymmärsin kehnolla germaanialla. Tosin enklanninkielisessä infossa oli jotain myös puhuttu suoraan maksun suorittamisesta Louikselle. Auttakkee
Miun kehnolla saksalla vorkasse kuulostaa enemman ennakkomaksulta.
Pistappas koko meili tuonne Babelfish ja katso tulisko siita mitaan tolkkua
Ja tärkeä pätkä tilausvahvistus e-mailista på engelska:
"Mode of payment: Vorkasse They receive inclusive dispatch and packing costs shortly from us a message with exact data concerning the total amount of your order. Please you transfer only then this total amount to one of our accounts. Their order is immediately made ready for dispatch after receipt of the amount and sent away to you. Resulting bank charges (10-20 EUR) are not carried by us. Please you consider in this connection during the transfer to fill out the appropriate field for resulting bank charges to your loads. Please you note in addition that the delivery time extends with vorkasse for organizational reasons to 10-14 days. Yours sincerely its on-line team the Louis Fun company Return instruction Return right you can the received commodity without indication of reasons within 2 weeks by return of the commodity return. The period begins at the earliest with receipt of the commodity and this instruction. Only with commodity not package-capable of being shipped (e.g. at bulky goods), you can explain the return also by cancelling demands in text form, thus e.g. by letter, fax or email. For keeping the punctual sending off of the commodity or the cancelling demand meets the period. In each case the return takes place at our expense and danger. The return or the cancelling demand wears to take place:
Detlev Louis GmbH
Rungedamm 35
21035 Hamburg
Tel-Nr: 040 - 73 41 93 60
Fax-Nr.: 040 - 73 41 93 47
E-Mail-Adresse: info@louis.de "
Vorkasse jäi sitten kääntämättä
Noh,mut toihan on ihan seleva
Ennakkoon maksu, ja maksaessa sinun tulee huolehtia etta kulujen jalkeen louisin tilille saapuva on summa jonka sinulle ilmottivat. Jossain varmaan on myos sitten tilinumero ja reference?
Onhan taalla naita Louisilta tilanneitakin, eli kun kotvan vuotat, ni varmaan tasmentavat yksityiskohtia.
Niijoo, ja taitavat alussa sanoa etta kohta perassa tulee tarkka summa postikuluineen, etta maksa vasta sitten
Louikselta en ole tilannut, Krauserilta telineet vorkassella ja Hein Gerickeltä mastercardilla roipetta. Krauserin tellinngit tilatessa maksoin ilmoitetulle tilille ilmoitetun summan ja pankille kohtuu hyvän riksan maksun välittämisestä. Muistaakseni pankki sai vajaan pari sataa markkaa, kun Krauserille meni jotain 700. Meilasin aiheesta Krauserille ja sain parin päivän päästä vahvistuksen jotta kamat lähti. Ja tuli myös. Kortilla tilaaminen on paljon edullisempaa kun pankki ei peri maksua.
Jos ei maksa Visalla, niin lähettävät laskun ennakkoon.
Ainoa huonopuoli on, että toimitusaika venähtää;
myyjä odottaa, että suoritus on tilillä (3-4 pankkipäivää) ja laittavat sitten tilauksen tulemaan (7-8 päivää)....
Eli Visalla maksettuna saa paketin kotiin tuossa 7-8 päivässä.
Se hyvä puoli tuolla Louisilla on, että paketti tulee kotiin asti. Ei tarvii lähteä sitä mistään hakemaan.
Yesh! Sama vika Rahikaisella. Tilaa luottokortilla, niin homma on halvempaa. Pankit perivät sikahävyttömät maksut rahan siirrosta. Esimerkiksi palvelupalkintoja jo kolmena vuonna voittanut vihtapankki rahastaa omia kulujaan 8 euroa ja vastapankin kuluja 22 euroa olipa siirto sitten sentin tai satatuhatta euroa. Järjetöntä. Eräs keino on liittyä internetissä toimivaan paypal-systeemiin. Se toimii yhtä halvalla kuin Visa tai Mastercard ulkomaan maksuissa ja ympäri maailman.
Aivan kuten Patrika sanoi.Jos käytät vorkassea maksuehtona; saat kohta postissa maksulapun jossa on tarkka summa (joskus käy niin ettei tule aivan kaikkea mitä on tilannut) menet sen kanssa pankkiin ja pankki lähettää maksun Louisille.(Jos haluat nopeuttaa hommaa, voit lähettää faksina pankin leimalla varustetun lapun Louisille) ja sitten vain jäät odottelemaan paketin tuloa.Varmista että laskun viite näkyy myös maksukuitissa->helpompi yhdistää maksu tilaukseen.
Ja yleensä paketti vielä tuodaan KOTIA...
Lasku kannattaa maksaa nettipankissa jos mahdollista esim. Nordea veloittaa nettimaksusta muistaakseni 6,5 euroa. Täytyy vain muistaa laittaa rasti kohtaan maksan KAIKKI kulut.
ja paketti on kotiinkannettuna jos paketin tuomisaikaan joku on vastaanottamssa.. jos kukaan ei ole kotona kun postin auto käy pakettia tarjoamassa vievät lähimpään postiin mistä sen saa hakea.
Joo, näinhän tää homma eteni, jotta lasku tulla tupsahti postiluukusta. Lasku maksettu, nyt venaillaan kamoja.
